TwinTurbo.NET: Nissan 300ZX forum - Advice on Passing CA Smog
Subject Advice on Passing CA Smog
Posted by twiztidZ on August 14, 2013 at 10:53 PM
  This message has been viewed 168 times.
Message Emission Control System Visual Inspection/Functional Check Result %C02 %O2 HC (PPM) CO (%)
Test RPM MEAS MEAS MAX GP MEAS MAX GP MEAS
IDLE 850 13.7 1.5 120 290 338 1.00 2.50 1.44
2500 2320 10.6 0.8 140 270 288 1.00 2.50 6.90
failed GP at 2500rpm with (270)
failed HC (PPM) MEAS idle with (338)
failed HC (PPM) MEAS 2500rpm with (288)
failed CO(%) MEAS 1.44 idle
failed CO(%) MEAS 6.90 2500RPM
Since then I clean my dual pop chargers with simple green
replaced the spark plugs with NGK Iridium IX heat range 8
complete oil/filter change.
Is there anything else I should do to hopefully pass the smog check here in California.
